Keith Browning Posted June 28, 2017 Share Posted June 28, 2017 I am working on a 2005 F450 with a 6.8L engine that has an engine mounted hydraulic pump. The pump uses it's own belt which means there is an add-on pulley on the crank. The water pump has an extended nose where the fan screws on - about 2" or 52mm as measured. Anyone familiar with this and have any idea where to source one? Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted June 28, 2017 Share Posted June 28, 2017 https://www.deweze.com/media/kit-manuals/700431F.pdf It appears in this ^^^ so I'd give DewEze a call and see what they say. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 28, 2017 Author Share Posted June 28, 2017 Thanx for the tip. I took a step back and reassessed. The add on crankshaft pulley had the Ford logo and a part number on it. Its from the 5.4L Lightning supercharger kit. Looked up a lightning water pump and there it was! The pump to removed had 8 impeller blades and the new one has 7 slightly larger blades so I think it will work just fine. It bolted right in and does not bind so I am keeping my fingers crossed. They actually ordered me a Gates 41121 Quote Link to comment Share on other sites More sharing options...
