william Posted June 28, 2017 Share Posted June 28, 2017 vehicle will not start. icp pressure will cranking is 430 ipr is at 85%. pulled valve covers and installed block off plugs to rail. cranked engine with icp at 85% icp builds to 2400, I believe it should build 4,000 psi. I removes turbo and air tested high pressure system and when commanding ipr at 85% I do not hear any leak. I think I hear some from the oil filter housing. it looks like it has a new icp sensor and possibly hpop but I believe it is bad. I would like to know what you guys think before I pull the trigger and replace the pump. I am a ford diesel rookie. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted June 29, 2017 Share Posted June 29, 2017 I have replaced a lot of swash plate pumps in the 03 to early 04. If it has no leaks and base oil pressure is okay then put a pump in it. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted June 29, 2017 Share Posted June 29, 2017 Does it build up to the 2400 steadily or is a saw tooth pattern? Quote Link to comment Share on other sites More sharing options...
KDS Posted June 29, 2017 Share Posted June 29, 2017 William, I would be much more interested the ICPV instead of whatever pressure the PCM decides to display. The 85% IPR duty cycle is certainly an indicator of a HPO system issue. Have you checked the base engine oil system yet? Every single one of those early pumps I have replaced had the drive end oil seal pushed out a bit. An internal failure of the pump will allow the high pressure to get out and push on the seal. You shouldn't be able to hear any air or gurgling in the oil filter housing. Even at 85%, The IPR is still open a little bit. You would need to block it off completely to truly "deadhead" the pump for a max psi reading. You are listening for a change in the air leak (flow) when you command the IPR open and closed. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 29, 2017 Share Posted June 29, 2017 And if you replace the pump do remember to replace the discharge tube seals. I have seen them burn techs several times. Quote Link to comment Share on other sites More sharing options...
william Posted June 29, 2017 Author Share Posted June 29, 2017 first image is with out block off tools installed. I did not check actual oil pressure with gauge while cranking just checked for oil coming up into filter housing while depressing the valve and cranking. when I pulled the pump out and turned it by hand it felt like it was binding and the freed up. Quote Link to comment Share on other sites More sharing options...
william Posted June 29, 2017 Author Share Posted June 29, 2017 on the bench I blew air into lower port of pump and put my finger over the other port and oil poured out of the front pump. Quote Link to comment Share on other sites More sharing options...
