5W40 Synthetic Discontinued From Ford
What are you guys using, for oil changes on Transits and F-Series for oil changes now, now that Mobil 5W40 Synthetic is discontinued from Ford? On F-Series, this might not be a big deal, since the WSM lists 0W40, 5W40, 10W30 and 15W40 as acceptable for use under varying conditions. But on Transits, the WSM calls for 5W40 only. I see that 0W40 is the only synthetic diesel oil available from Ford now. Does that mean we should be using this on Transits, and on F-Series trucks where customers specifically request synthetic?
On my own truck, I've been running 5W40 synthetic since new. Would making the switch to 0W40 hurt (or help)?
Is that what is going on. The last time I changed oil the parts guy said the listing on his motorcraft supplier's site was weird.
I'm not sure what I'm gonna run yet. I think we have some on the shelf yet. I might see if they will set it aside for me. At least in 3 jug increments.
Where did you see that it is discontinued?  Yes the part number did change a little while ago but that may have been with the new CK-4 spec.  Also only the 5qt jug changed part numbers, not the 1 quart bottle.  This was in the US at least.
