kellyf Posted August 14, 2017 Share Posted August 14, 2017 Pulled the dog house on this on and line at left treat of engine leaking fuel. I think maybe this is a return line. Seemed a while back We got a set of fuel injector return lines which had a name. Also the flow plug module platic at the bottom is turning in to goo maybe from the fuel. I drove it for what was a trans shift concern, but it starting surging and barely made back to dealer and cut off and now a no start.we maybe have a working ngs. No turn signals ,wipers don't work and and light on with no speedometer. Thinking maybe that's a diff speed sensor. More fun for me! Quote Link to comment Share on other sites More sharing options...
kellyf Posted August 15, 2017 Author Share Posted August 15, 2017 the fuel leak appears to be from a a hose on the left back side of the block as viewed with the doghouse off. Is this a return line. I have heard of air intrustion causing no starts.is there a name for the fuel line return kit and if so does it include this line? I have little experience on older 7.3 engines with mechanical injector pumps. Any help apprieciated Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted August 16, 2017 Share Posted August 16, 2017 Lots of good info here http://www.forddoctorsdts.com/topic/5477-1993-73-idi/?hl=hose I can get you the hose part# tomorrow if your parts guy can't find it. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted August 16, 2017 Share Posted August 16, 2017 The ambulance I had written that post about is still going strong. Quote Link to comment Share on other sites More sharing options...
kellyf Posted August 16, 2017 Author Share Posted August 16, 2017 Thank you sir. Can you get me the hose number please? Also what kind of labor are we looking at? Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted August 16, 2017 Share Posted August 16, 2017 New # FOTZ9324F or KFL84 What I have is the old # E3TZ-9324-A Quote Link to comment Share on other sites More sharing options...
KDS Posted August 16, 2017 Share Posted August 16, 2017 Return line kit. Dipaco makes some kits for the IDI's. They come complete, Hose, Caps, O-rings and clamps. I keep 1 in stock as I have a couple of IDI's and I service a few. www.dipacodtech.com Quote Link to comment Share on other sites More sharing options...
kellyf Posted August 17, 2017 Author Share Posted August 17, 2017 Thanks for the help Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted August 20, 2017 Share Posted August 20, 2017 Speaking about injector pump diesels. Does anyone have good source for clear hose for diagnosis? Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted August 20, 2017 Share Posted August 20, 2017 The local ace hardware store has it on the roll. Not sure how well it holds up to fuel. Otherwise I can buy a blue colored see through line that is made for snowmobile carbs. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted August 21, 2017 Share Posted August 21, 2017 All hardware stores and Home Depot have vinyl hose on the shelf from 1/16" through 1 inch or bigger, $10-20 will get you a couple of feet of each size. Vinyl holds up for a while but will turn very hard and yellow with age. For short term testing it's fine. Quote Link to comment Share on other sites More sharing options...
