Steve Mutter Posted December 5, 2017 Share Posted December 5, 2017 I have a 2011 I just put a def tank in for code p21bo, I have no codes now koeo koer passed and the tank is full. It will not let me complete the re fill activation it will always kick me out and say procedure was unsuccessful. Has anyone else run into this, the tank level pid show %100 but it still will not re set in the dash. Quote Link to comment Share on other sites More sharing options...
lmorris Posted December 12, 2017 Share Posted December 12, 2017 Are you plugged into something that is T'd into the factory DLC? We get a lot of trucks with GPS units that plug into the DLC and you can't run a lot of reset functions if you are plugged into the GPS unit's connector. 1 Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted December 23, 2017 Author Share Posted December 23, 2017 I ended up performing a pmi by making it think the pcmcia was blank, and then for some reason after it re set itself. It still wouldn't let me perform the re fill activation but it was a bell bucket truck with a tee in for the GPS, I will have to try the next time. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted January 3, 2018 Share Posted January 3, 2018 I have been screwed so many times by those t-in gps units, i disconnect them and plug straight into the oem dlc right from the start. Don't ever try to program a pats key with one of those on the network. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted January 5, 2018 Share Posted January 5, 2018 I too have had problems with interfaces teed into the DLC mostly with ambulances and a bucket truck or too as well. Sometimes you don’t know it’s there until you pull the lower dash trim off and look around. Quote Link to comment Share on other sites More sharing options...
DieselD Posted January 29, 2018 Share Posted January 29, 2018 We run those GPS units as well. I install them in a fashion where they have to be unplugged before anything else plugs into the DLC Quote Link to comment Share on other sites More sharing options...
