Spark plug tools
Hey guys. Been a long time since I’ve posted but been swamped the last 6 months.  I have a 2 valve 6.8 that showed up with a blown out spark plug.  Wondering what tools you guys have found works best for this particular job? Also have a 3v 5.4 on the schedule for a spark plug change.  Wondering what your preferred tool is for dealing with broken plugs.  Murphy’s law says if I’m prepared for the worst I won’t need the tools.  Ha ha ha. Thanks for the input guys..
For the 3 valve I always do an induction cleaner the PM before, then the next morning I use a 3/8 impact & a air regulator or my 3/8 cordless to remove them. With this method only had to remove 1 broken plug so far.
One time someone tried to do plugs himself & broke some of the plug so I couldn't run the vehicle to do the induction cleaner. Every plug broke & the Lisle tool worked great.
Thanks guys I’ve heard guys talk about the lisle 3v kit and the timesert set up for 2 valves.  But wanted opinions from guys that have actually used them likely quite a bit.
