6.7L Short/Long Bock Changes
Keith Browning
If you order a new long or short block be aware that to make the engines accommodate both pick up and medium duty applications that the engine mounts and bolts have been changed and may require replacing depending on model year. Also there are two coolant passages on the front cover that will need to have plugs installed on pick up applications... order those too!
