jimmy57 Posted April 18, 2018 Share Posted April 18, 2018 I think the DRB's of the automotive engineering world need to be recognized. I suggest the Dirty Rotten Bastard Wall of Shame. I nominate the turd that put the pressure port for the power steering pump above the bolt that holds it to blocks, timing covers, etc. Especially when it has to be removed for access and adds complexity for NO reason. I nominate the turd that placed the back turbo bolt on first gen 6.0 turbos. I nominate the turd that controls heat shield bolt placement. There are plenty more, please nominate more. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 18, 2018 Share Posted April 18, 2018 I nominate that guy that designed the 6.7L water pump that is like 18" long instead of using the modular style pump. Quote Link to comment Share on other sites More sharing options...
RyanG Posted April 18, 2018 Share Posted April 18, 2018 I nominate the guy that changed the design of the 6.7 down pipe when doing a turbocharger. I will think of more, this example was fresh in my mind. Oh wait!... Anybody that had anything to do with the design of the 6.4. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted April 18, 2018 Share Posted April 18, 2018 How bout the guy who decided that it’s too much work to install the dowels on the 3.2 at the factory. Or the guy who designed the Transit period. Quote Link to comment Share on other sites More sharing options...
Fredsvt Posted April 18, 2018 Share Posted April 18, 2018 The idiot who couldn't make the core support on a transit connect unbolt from the top. So when changing a radiator you get constantly dripped on, even after capping off hoses and rad fittings because the damned radiator drain sprays like a sprinkler all over the place. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted April 20, 2018 Share Posted April 20, 2018 The person who thought it is a good idea to make radiators without drain plugs. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 20, 2018 Share Posted April 20, 2018 On that note... WHY is the drain valve on a 6.7L secondary radiator facing FORWARD instead of to the side like the primary? Quote Link to comment Share on other sites More sharing options...
jw33 Posted April 20, 2018 Share Posted April 20, 2018 1 hour ago, Keith Browning said: On that note... WHY is the drain valve on a 6.7L secondary radiator facing FORWARD instead of to the side like the primary? I don't even mess with the drain on the secondary, pull the hose on the transmission cooler is a whole lot easier and quicker 1 Quote Link to comment Share on other sites More sharing options...
