Keith Browning Posted May 8, 2018 Share Posted May 8, 2018 Can it be done easily in chassis? I cant even remember if I have ever done one. Trans out? Turbo off? Jack the engine up high enough? Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted May 9, 2018 Share Posted May 9, 2018 I always just tugged the whole thing out. That way I can invert the sucker so the silicone can cure the right way. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 9, 2018 Author Share Posted May 9, 2018 Of course that would be optimal however this is an aging ambulance. Either way it will be labor intensive. Looking at options on this unit to be re purposed or dumped. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted May 9, 2018 Share Posted May 9, 2018 Dumped would be the best alternative. A vehicle that old isn't worth the money or the labor required for the repair in question. In answer to your question though, yes it can be done with the transmission removed and the engine raised slightly without needing to remove the turbo. I know this is because I've personally seen it done. Whether or not I agree with this method is another story though, for the same reason already mentioned above. Quote Link to comment Share on other sites More sharing options...
djmiller Posted May 10, 2018 Share Posted May 10, 2018 I've done it in there, but pull the turbo out to get that much more room. Clean the deck thoroughly, allow ample dry time. Make sure the RTV is fresh, and get an extra set of tiny hands to help with the pickup tube. Not the preferred method, but sometimes what you will destroy along the way that's all rotted out will make the repair too costly for the client. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted May 10, 2018 Share Posted May 10, 2018 On 5/8/2018 at 6:21 PM, Keith Browning said: Can it be done easily in chassis? I cant even remember if I have ever done one. Trans out? Turbo off? Jack the engine up high enough? Expand You could just do the backyard fix that’s been showing up around here on the superduty’s. Cut the crossmember out and then re-weld it back in. Cause that’s the right way to fix a rotted out oil pan. NOT!!!!!! Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 10, 2018 Author Share Posted May 10, 2018 Yeeeehyeahhhh. no. Quote Link to comment Share on other sites More sharing options...
lmorris Posted June 14, 2018 Share Posted June 14, 2018 Might be worth a look. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 17, 2018 Author Share Posted June 17, 2018 Been a while since I saw these knuckle heads! I think I posted this vid quite a while ago... they are in Jersey too. Although this is such a hack I certainly can understand why some people opt for this kinda stuff. I have seen one truck with this glue on pan repair. At least these guys are not cutting crossmembers to get the pan out and welding them back in. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted June 17, 2018 Share Posted June 17, 2018 I got 2 words for you.... Flex Seal. 1 Quote Link to comment Share on other sites More sharing options...
