2003 6.0 vibration
have a straight gear zf trans with a terrible shake at idle,anyone seen a dual mass flywheel on a 6.0 all the ones i've seen are not but it shakes like one touch the throttle and it goes away then comes back. any ideas it feels like a bad miss but leaves under load
Just replaced adual mass flywheel on early build 04 f550. Dampening springs in flywheel were breaking up and causing a rattle noise and contributing to a rough idle. Current ford parts catalog now lists a change up to a one piece flywheel. Appears that there is no more dual mass flywheels available; at least in canada. BTW the damaged dual mass had over 1.5" of freeplay.
For some reason, early 450/550 (and, possibly 350DRW - can't remember) came with dual mass flywheels. IIRC, these parts are superceded by single mass flywheels. Be sure to order new flywheel bolts at the same time....
