Brad Clayton Posted July 26, 2018 Share Posted July 26, 2018 We got one of these things in the shop, I forget the mileage but it makes a strange, rhythmic thumping noise at idle when hot. The noise seemed to be localized to the right side of the engine in the valve cover. The VC was removed and the usual valve stuff was examined and deemed ok. The timing chain tensioner shows about 4 teeth. The vacuum pump (cam driven) was looked at and full of oil so it was replaced and we thought that was it. Still makes the noise. Then the alternator belt was removed and the noise disappeared. The belt is clean, and the water pump was removed and it looks fine, no looseness in the internals or anything like that. The alternator spins freely. Not a whole lot of info, I know but curious if anyone has heard any strange noises from these engines other than the cold rattles. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted July 26, 2018 Share Posted July 26, 2018 We had one the other day that sounded like it was knocking from the bottom end. 103,000 miles on a 13 f150. Cut the oil filter open and found this. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted July 27, 2018 Author Share Posted July 27, 2018 Yikes. So I am not working on the one in this post but I think they are putting a new water pump on it and rechecking. We will see. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted July 27, 2018 Share Posted July 27, 2018 I found a message today about cracked piston skirts on some of the 3.5 ecoboost motors. Your truck should be included in that. I’ll try and remember to find it again tomorrow. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted July 27, 2018 Share Posted July 27, 2018 47394 2013-2018 F-150, 2015-2018 Transit/Expedition, 2015-2017 Navigator - 3.5L EcoBoost - Engine Tick Type Noise From Cylinder Block Some 2013-2018 F-150, 2015-2018 Transit/Expedition, and 2015-2017 Navigator vehicles equipped with a 3.5L EcoBoost engine with greater than 20,000 miles may exhibit a tick type noise from the cylinder block area. This noise may be caused by a cracked piston skirt. The noise can be isolated to a cylinder using a stethoscope or other suitable listening device. Canceling the affected cylinder will reduce or eliminate the noise. If the noise is isolated to a specific cylinder, it is recommended to replace the short block. If the noise cannot be isolated using the methods described, refer to the Workshop Manual (WSM) for diagnosis. A cracked piston skirt does not result in metal contamination of the engine or any related cylinder head damage. Prior approval for short block replacement is not required under new vehicle limited warranty coverage. EFFECTIVE DATE: 29-JUNE-2018 Quote Link to comment Share on other sites More sharing options...
cbriggs Posted August 9, 2018 Share Posted August 9, 2018 I've seen (more than once) a small rock stuck in a pulley groove, makes a noise that you would never imagine it could. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted August 9, 2018 Share Posted August 9, 2018 That’s gotta be a very special stone. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted August 10, 2018 Author Share Posted August 10, 2018 Looks like we wont be getting to the bottom of this one. The customer traded it in and the truck went bye-bye. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 10, 2018 Share Posted August 10, 2018 Sometimes that is the best resolution overall. Quote Link to comment Share on other sites More sharing options...
