mchan68 Posted August 5, 2018 Share Posted August 5, 2018 This is my truck. Just this last week, it has began howling as though it's stuck at 100% duty cycle all the time. Has anyone else ran into this? My truck is not overheating either. No DTCs. Just a straightforward fan clutch replace and life should be good? Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted August 5, 2018 Share Posted August 5, 2018 Yup. Had one do it on a chassis cab during the road test after replacing the radiator. Just make sure the commanded duty cycle is at 0ish. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 5, 2018 Share Posted August 5, 2018 I've had a couple myself... just roaring away for no reason. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted August 5, 2018 Share Posted August 5, 2018 If it does it with connector unhooked it has to be something in the clutch. Also check the fan mount pulley for play, wobble and noisy bearing. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted August 6, 2018 Share Posted August 6, 2018 I have replaced a ton of these fan clutches on the 6.7's Quote Link to comment Share on other sites More sharing options...
leavnon3rd Posted August 21, 2018 Share Posted August 21, 2018 ive done a lot of clutches, straight forward. I leave the shroud in and unbolt the fan from the clutch. be careful witht he harness and connector attached to the long 13mm w/p bolt 1 Quote Link to comment Share on other sites More sharing options...
mchan68 Posted August 21, 2018 Author Share Posted August 21, 2018 On 8/21/2018 at 12:56 PM, leavnon3rd said: ive done a lot of clutches, straight forward. I leave the shroud in and unbolt the fan from the clutch. be careful witht he harness and connector attached to the long 13mm w/p bolt Expand That was exactly how I did mine. Bonus that this part was under warranty too. Quote Link to comment Share on other sites More sharing options...
