oil around exhaust ports on left head
there is oil around all 4 exhaust ports on the right clynder head no oil is above or below just around the ports and on the exhaust manfold,
had a FORD remain engine put in it 13,000 miles ago
any ideas?
passenger side is bone dry
Does the truck run rough? Does it smoke? Is it using coolant? An injector or a crack somewhere in a forward cylinder like #1 could be dumping a lot of fluid into the exhaust manifold and it is seeping out from the port areas. Fuel and coolant can look like oil when it mixes with exhaust carbon. A crack in the cylinder head leaking coolant into the exhaust port would do it.
