01 f350 need help with altnerator connector
Yeah you wont find the connector view because some idiot at Ford Motor Company decided to intentionally omit connector views for connectors with less than 5 pins.  If your eyes are good you should be able to see the pin numbers molded into the back of the connector. And FWIW the wiring diagram shows it's connector C185 or am I seeing things?
