Stalls From Wipers
We had a 2002 in that did this, it needed to be on intermittent wipers to happen but it was very easy to duplicate on just about three interval swipes.
Turned out to be the CMP sensor was picking up RF interference. It was also an aftermarket sensor if that matters.
Nope. That was done years ago. The sensor looked pretty new too but the tech working on it indicated that it was definitely aftermarket so what was someone trying to fix? The same concern? If that is the case I expect to see the truck back in the shop before long.
A few years back I had an 02 that would stall anytime the driver used his VHF radio. Very repeatable, key the mic, engine would die. Never did fix it, he just removed the radio and used a handheld instead.
