Keith Browning Posted March 24, 2019 Share Posted March 24, 2019 Mar 22 2019 7993 - 2012-2016 F-Super Duty - Battery Cable Clamp Corrosion Repair Some 2012-2016 F-Super Duty vehicles may exhibit a battery cable clamp corrosion concern at the positive battery terminal. It is not necessary to replace the complete battery cable harness CC3Z-14300-A for this concern. Positive battery cable clamp BT4Z-14450-AA is available and can be used to replace just the corroded terminal. Do not cut or shorten the battery cable, but instead remove the corroded battery cable clamp and clean the cable end as necessary. Bend the new battery cable clamp as needed and crimp it to the existing battery cable. Make sure to use heat shrink tubing over the battery cable to battery cable clamp connection. Obtain the heat shrink tube locally. What about the negative cable? Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted March 25, 2019 Share Posted March 25, 2019 It’s not on back order so they don’t care. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted March 25, 2019 Share Posted March 25, 2019 Quote Link to comment Share on other sites More sharing options...
