batmantech Posted April 30, 2019 Share Posted April 30, 2019 2001 f-250 6.8 126,000 miles. ABS light would flicker on and off finally stayed on. Unable to communicate with module. Powers and ground to module ok. Loaded all wires. Installed used module clear codes fine , ran datalogger, test drive-- after driving light flicker on off then stayed on. unable to communicate with ABS again. Unhook connectors reconnect original module now I can communicate ok. I thought it had to be how I was moving the wires to connect it but all seem fine. Anyone have any experience with this type of situation? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 1, 2019 Share Posted May 1, 2019 To me it still suggests a wiring issue. Now, for the discussion can we assume that after reinstalling the original module the concern has returned? (yet) I bet it will sooner or later. Moving harnesses around can fix things temporarily as I am sure you know well. Did you check pin fit? Quote Link to comment Share on other sites More sharing options...
batmantech Posted May 1, 2019 Author Share Posted May 1, 2019 I checked pin fit. Some did have a better fit than others. So I tightened the fit reinstalled everything. Then drove 2 times so far it's working. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted May 3, 2019 Share Posted May 3, 2019 Without looking up SI, some early RABS systems did not talk on the bus but rather used blink codes. Is it RABS or 4WABS? Quote Link to comment Share on other sites More sharing options...
batmantech Posted May 8, 2019 Author Share Posted May 8, 2019 Its 4WABS. Since tightening the pin fit it has been working ok Quote Link to comment Share on other sites More sharing options...
