TPMS Placard Adjustment
JoeR
GM and Ram Pickups are capable of adjusting the desired tire pressures up or down depending on what the customer needs.
For instance if you have a 3/4 ton truck but never carry anything in the bed.  Having 80PSI in the back tires is not desirable.  You can change that to 50 PSI, change the placard on the door, and run 50 PSI instead of 80 PSI with no TPMS light.
I've never seen that ability on Ford vehicles.  Am i just missing it in the IDS or is it not a function on Fords?
Thanks!
Joe
We have an Autel tpms tool that will adjust placard pressure on all current ford vehicles. I have some bright red labels made to put next to the load placard in the door jamb to indicate it has been lowered.
