FordFanaticTony Posted September 16, 2019 Share Posted September 16, 2019 Installed new thermostat and ect sensor the vehicle stays cold. No codes during self-test. next step is taking an actual reading with a temp gun. Anyone ever seen this? Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted September 16, 2019 Share Posted September 16, 2019 Is that actually ect and not cht? If I remember right the ect sensor on those only make the gauge work and the pcm never sees it. Quote Link to comment Share on other sites More sharing options...
FordFanaticTony Posted September 16, 2019 Author Share Posted September 16, 2019 I replaced the coolant sensor on the front cover that goes by the thermostat housing. Quote Link to comment Share on other sites More sharing options...
FordFanaticTony Posted September 16, 2019 Author Share Posted September 16, 2019 Just looked at the schematic. Going to check out the mat and eot also since they share the signal return from the ect. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted September 17, 2019 Share Posted September 17, 2019 Oops. I mixed up 6.0 and a gas motor. Disregard the cht question. What’s the eot read when the coolant temp says low? Quote Link to comment Share on other sites More sharing options...
cbriggs Posted September 17, 2019 Share Posted September 17, 2019 After a cold soak do ECT, EOT and IAT 1 & 2 all match? If it is an NTC thermistor as temp goes down, resistance goes up, so resistance in the circuit will show as low temperature. ( I can't open wiring diagrams on my home pc to verify, just brainstorming...) Quote Link to comment Share on other sites More sharing options...
FordFanaticTony Posted September 17, 2019 Author Share Posted September 17, 2019 Well glad I looked at the schematic beforehand. Someone worked on this 03 before so they plugged the IAT2 to the ECT and vice versa. Always beware of the previous guys work. Thanks fellas for any tips and advise as always. 1 Quote Link to comment Share on other sites More sharing options...
cbriggs Posted September 25, 2019 Share Posted September 25, 2019 Hahaha. That's a new one. Glad you figured it out. Quote Link to comment Share on other sites More sharing options...
