Wiper Motor
8WA Sman
The OE wiper motor on my '94 F-150 has failed and  after much digging I secured a WM-548. My OE motor has two 3 pin connectors, the replacement motor has one 5 pin connector. At one time these motor had instructions but mine does not. After more digging I came across a site that basically says to merge the ground with motor common.
Does anyone remember or can confirm this?
I do not want to damage the wiper module as I am guessing it is probably more OBS then the motor :cover:
  • Like 1
Looking over the wiring diagram, that does make sense. I do recall doing a few of these years ago. All the other wires in that harness are going to be powered anyways. If you look at newer vehicles the ground and motor common are merged in the wiper motor already.
