kellyf Posted January 24, 2007 Share Posted January 24, 2007 Hi Guys, have this 2004 6.0 f-250.Customer states just quit while at highway speed.Towed in.Crank no start.Has po263 and 272.There is a ssm concerning test p which is asking for some test on ficm curcuits.Thought I would run a buzz test just for kicks.Wow! First stage all buzz or click except number 4.Next round only five injectors click,Then a somewhat long pause and misses almost all.Test results passed injector test.Have fuel pressure.Has any one run into this before?Did look for chaffing,but found none.Thanks Quote Link to comment Share on other sites More sharing options...
DamageINC Posted January 24, 2007 Share Posted January 24, 2007 Wow, that is kinda messed up. I can say that I've seen fuses that weren't installed properly in the Battery Junction Box (from the factory) and they've caused all sorts of odd, intermittent problems. Although I've yet to see one cause any noticible driveability concerns (aside from check engine lights), I'm sure that it's possible. It's funny, they look like they're properly installed, but on closer inspection you can see that the fuse blades aren't really installed into the female pins in the junction box - rather, they get smashed "next" to the pins and don't always make good contact. Any chance that maybe the FICM isn't installed properly? (Maybe it was previously removed and the brackets were bent or something, now it's forcing the connectors & wiring that plug directly into the FICM to smash into the valve cover or something??) Dave Quote Link to comment Share on other sites More sharing options...
kellyf Posted January 24, 2007 Author Share Posted January 24, 2007 now clicks on every injector,but sets hard fault for every injector.this sounds like ficm to me Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted January 25, 2007 Share Posted January 25, 2007 The most similar concern that I can think of was one that had the FICM connectors not fully seated. It would keep setting different injector codes on the buzz test. Quote Link to comment Share on other sites More sharing options...
