lmorris Posted February 21, 2020 Share Posted February 21, 2020 Has some funky shifting and engagement issues. Found transmission fluid in the bulkhead connector. Fluid is black and metallic. Removed and tore down transmission. Lots of metal in bottom of case, almost sand like in texture but not big chunks. All internals that I can see are fine. Some heat marks on intermediate clutch pressure plate. Steels and fibers are in surprisingly good shape. Torque converter looks like it was overheated. Does all this metal come from the torque converter? Looks like they got it stuck in a snow bank and possibly tried to drive it out. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted February 21, 2020 Share Posted February 21, 2020 Any codes? Quote Link to comment Share on other sites More sharing options...
lmorris Posted February 21, 2020 Author Share Posted February 21, 2020 Just 6 gear incorrect ratio code. Thing has intermittent no reverse. And harsh downshifting, even with the select shift. Once it held 3rd for a while then shifted to 4th. I suspect most of this is caused by all the metal in the main control. I'm just stumped as to where all the metal came from. I haven't got the pump apart yet. I don't think low pressure is an issue though. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted March 28, 2020 Share Posted March 28, 2020 The input shaft is bad about stripping out where the splines meet up in the converter. At first glance they look ok but if they are at fault they will be intact but kinda flat and wider than normal. This scenario sends a bunch of powered metal into every nook and cranny. Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 30, 2020 Author Share Posted March 30, 2020 In the end I ended up having a replace decision on cost cap. I'll keep the input shaft in mind if I get another. 1 Quote Link to comment Share on other sites More sharing options...
