Keith Browning Posted February 21, 2020 Share Posted February 21, 2020 If you have experience with these engines you know there is a history of valve springs breaking - usually causes misfiring and popping noises or at the very least the MIL will be on. Now we have something new. I have had two trucks with what seemed to have a valvetrain noise which I could not determine which side it was coming from. No misfires, no MIL. If you get one doing this start an IDS session and bring up data logger and select IMRC_MODE and start. Turn it on. If the noise goes away replace the intake manifold. BTW the manifolds are currently on back order (gheee realllly?) so I haven't had the chance to dissect the IRMC issue. I also read two Hot-Line reports with the same issue and repair with positive results. Quote Link to comment Share on other sites More sharing options...
Chad_Kelsoe Posted February 26, 2020 Share Posted February 26, 2020 I had one of these trucks about a year ago. After conferring with hotline, we determined it was indeed the IRMC actuators causing the noise, and replacement of the manifold solved the noise. Haven't seen one making noise since and that truck has not returned. Quote Link to comment Share on other sites More sharing options...
YukonTyler Posted February 28, 2020 Share Posted February 28, 2020 Wasn't there a bulletin for this back in the day? I could swear there was an SSM saying normal function, do not replace the intake (under warranty), or something to that effect. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 28, 2020 Author Share Posted February 28, 2020 I could not find anything on this at all as far as SSMs and TSBs go. I don't see how this hoise could possibly considered normal in any way. Quote Link to comment Share on other sites More sharing options...
