lmorris Posted March 20, 2020 Share Posted March 20, 2020 Just replaced the valvebody/solenoid body on a 66RFE. Filled the transmission with fluid total of 9 liters. Transmission has no reverse or drive now. Made sure the shift linkage was lined up. Tried to perform the TCM quick learn and it fails then I get codes for no pressure. Pulled pan and checked my install. All is good. The secondary filter is full and the fluid is warm, which tells me the pump was actually moving fluid. My question is: Are there any tricks to this? I am using Prodemand for service procedures. We think the new valvebody is bad. Just want to be sure. Thanks. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted March 21, 2020 Share Posted March 21, 2020 Got a VIN and part number used? Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 24, 2020 Author Share Posted March 24, 2020 3C6TR5DT5FG566915 Part#5211 9450 AK-001 Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted March 25, 2020 Share Posted March 25, 2020 The valve body I come up with is RL166834AM Was the solenoid pack color the same as the old one? Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 26, 2020 Author Share Posted March 26, 2020 On 3/24/2020 at 7:32 PM, 8WA Sman said: The valve body I come up with is RL166834AM Was the solenoid pack color the same as the old one? Your number changes up to what we have. All the solenoid bodies had the same color-grey. Second valve body is in and I still have no engagement. 0 PSI line pressure. I can't even check line pressure manually because we have no tools for this thing. Pan is off again. Everything looks to be installed properly. We are suspecting a damaged filter now. Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 26, 2020 Author Share Posted March 26, 2020 Got it figured out. The replacement valvebody was missing 7 oil gallery plugs. Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 27, 2020 Author Share Posted March 27, 2020 At this point one would think it would be a matter of switching the plugs from the original valve body into the new one. Not so. Even though we now have confirmation from 2 other Dodge sources that the plugs are supposed to be ordered separately when ordering the change up valve body, the Dealership we deal with is insisting they are supposed to come with the valve body and they see no note that says otherwise. So now they have gotten us yet another valve body from another dealer and we are to send back the 2 they sent us. Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 31, 2020 Author Share Posted March 31, 2020 Update:After getting the valvebody issue figured out and getting the transmission to shift past 5TH we found that it slips in 6TH. Thanks to a local rebuilder giving us a steal of a deal we are now putting in a reman unit. Quote Link to comment Share on other sites More sharing options...
