05-06 500's with wrench light on, then off, no dtc
There is an issue with the 500's with the wrench light coming on intermitantly with no dtc's. There is one concern where the wrench light will come on and message center says "failure safe mode," that is where u follow thje TSB. There is another concern that we just found with the wrench light coming on int. when u press on the dash above the instrument cluster the light will come on dimly, and let go it will go away. we have had 2 of them so far with the harness chafing above the cluster. Watch out for that, but do not do it if the customer says "message center said failure mode"
That's funky - haven't seen that one yet. LOL To be honest, I haven't had anything that requires any brain-usage in a while, it sucks. Last thing that was even remotely interesting was an '05 Focus wth the horn stuck on, needed a GEM. Other than that, I've been busy with engine work and rear-end overhauls.
Dave
