Steve Mutter Posted November 14, 2020 Share Posted November 14, 2020 I have a 2011 6.7 with almost 300 km, doing a fuel system because it ran on gas till it stopped. #1 and #7 broke off in the head. I started on #1 and can't even get it to move one bit. I got the valve cover off and got a good grip on the bolt and now it broke off flush. What technique have you guys used that has work for you ? The hold down clamp on #1 was broken and loose so it may have damaged the threads maybe making hard to remove. Has anyone used the promaxx repair kit ? is it worth it? I checked today and go figure cylinder heads are back ordered so that not an option. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 14, 2020 Share Posted November 14, 2020 Holy crap! That kit is $500! https://www.promaxxtool.com/diesel-tools/p/nico Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted November 15, 2020 Author Share Posted November 15, 2020 I bet by the time it get's to Canada it will be close to $800. I was just hoping someone here could tell me if it works good or not. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted November 15, 2020 Share Posted November 15, 2020 No idea. Only used their hub puller. Which is the cats ass for explorers. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted November 17, 2020 Share Posted November 17, 2020 On 11/15/2020 at 5:18 PM, forddieseldoctor said: Only used their hub puller. Which is the cats ass for explorers. Would you care to elaborate? I just clicked on that link and couldn't find that tool. All I could find on their website is drill guide kits for exhaust manifolds for the common engines needing them but no hub pullers. Changing out hub and bearing assemblies on Explorers is on my hate list of jobs and if such a tool exists to make this job tolerable, it's worth the investment. Sorry for the thread derail. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted November 17, 2020 Share Posted November 17, 2020 I have the hold down bolt drill guide from them works great. Yes ,way to expensive but works great 1 Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted November 17, 2020 Share Posted November 17, 2020 16 minutes ago, mchan68 said: Would you care to elaborate? I just clicked on that link and couldn't find that tool. All I could find on their website is drill guide kits for exhaust manifolds for the common engines needing them but no hub pullers. Changing out hub and bearing assemblies on Explorers is on my hate list of jobs and if such a tool exists to make this job tolerable, it's worth the investment. Sorry for the thread derail. Stupid expensive but does work good for explorer wheel bearings https://www.promaxxtool.com/extractors/p/tommy?rq=tommy Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted November 20, 2020 Author Share Posted November 20, 2020 On 11/16/2020 at 8:42 PM, tonybullitt said: I have the hold down bolt drill guide from them works great. Yes ,way to expensive but works great I just saw that there is a prokit plus that comes with inserts, can you just get by with the prokit or are the inserts a must. 2 Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted November 24, 2020 Share Posted November 24, 2020 On 11/20/2020 at 5:54 PM, Steve Mutter said: I just saw that there is a prokit plus that comes with inserts, can you just get by with the prokit or are the inserts a must. I got the kit with inserts but haven't used one yet. 2 Quote Link to comment Share on other sites More sharing options...
hitechmech Posted November 24, 2020 Share Posted November 24, 2020 i have had good luck drilling threw center and then build up with weld and attach nut, they come out good then. 1 Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted December 11, 2020 Author Share Posted December 11, 2020 Success ! The promaxx tool worked nicely except the small drill bit broke right at the end. I was able to mig the other side out first try. 2 Quote Link to comment Share on other sites More sharing options...
