cbriggs Posted December 13, 2020 Share Posted December 13, 2020 Wondering if anyone can help me. I am helping a friend install a PTO (for a crane) on a 2012 international 4300, 4wd, with a maxforce engine and allison trans. It has the OE PTO switch in the dash, but did not previously have a PTO installed. We are looking for electrical connection points, and info on rpm control, and if any programming is required to turn on PTO capabilities. Thanks! Quote Link to comment Share on other sites More sharing options...
KDS Posted December 15, 2020 Share Posted December 15, 2020 Can you post the VIN? I'd like to see what modules the truck is equipped with. There are a few different ways to wire it. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted December 18, 2020 Author Share Posted December 18, 2020 OK I will get it on saturday. Thanks! Quote Link to comment Share on other sites More sharing options...
cbriggs Posted December 20, 2020 Author Share Posted December 20, 2020 VIN is 1HTMZSKN1CJ093320. Quote Link to comment Share on other sites More sharing options...
KDS Posted December 20, 2020 Share Posted December 20, 2020 90BODY INTEGRATION0060AAABDY INTG, REMOTE POWER MODULE Mounted Under Cab or On Battery Box, Up to 6 Outputs & 6 Inputs, Max 20 amp per Channel, Max 80 amp Total; Includes 1 Switch Pack with Latched Switches 91BODY INTEGRATION0060ABEBDY INTG, PTO ACCOMMODATION for Electric over Hydraulic PTO, Does Not Include Solenoids, with Latched Switch Mounted on Dash Includes Audible Alarm and Indicator Light in Gauge Cluster (Requires 1 Remote Power Module input & 1 output) Find the Remote Power Module (RPM). There will be a 6 cavity plug. One of those output pins will be controlled by the PTO dash switch. A dealer "should" be able to provide you with terminals if you need them. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted February 27, 2021 Author Share Posted February 27, 2021 Thanks for your help. I've got the pto up and running, but I need to wire the feedback signal to an input on the remote power module, to turn on the pto indicator lamp when it is engaged. Any Idea what pin it needs to be connected to? I found a ton of diagrams online, but none provide a pin location for the feedback signal, only saying that it needs to be connected to an input on the 23 pin connector of the RPM. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted February 27, 2021 Share Posted February 27, 2021 Can you just tap into the output circuit that would go to the pto clutch? Quote Link to comment Share on other sites More sharing options...
cbriggs Posted February 27, 2021 Author Share Posted February 27, 2021 The PTO assy has a switch to indicate it is engaged, but to turn on the Indicator light in the instrument cluster, I need to connect it to the remote power module, as the module communicates over a CAN network to the IC and switch pack. One of my suggestions was to install an external light on the dash, but the owner would prefer it to light the OE equipped lamp in the IC. A feed back is also required if alarms, warnings or cutout logic is to be programmed into the remote power module. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted February 28, 2021 Share Posted February 28, 2021 9 hours ago, cbriggs said: The PTO assy has a switch to indicate it is engaged, but to turn on the Indicator light in the instrument cluster, I need to connect it to the remote power module, as the module communicates over a CAN network to the IC and switch pack. One of my suggestions was to install an external light on the dash, but the owner would prefer it to light the OE equipped lamp in the IC. A feed back is also required if alarms, warnings or cutout logic is to be programmed into the remote power module. Ah. I understand now. I was assuming it was an external light. Quote Link to comment Share on other sites More sharing options...
