Keith Browning Posted February 28, 2021 Share Posted February 28, 2021 Any of you reseal and upper oil pan under ESP and how was it coded and did it fly? Failed part the pan itself? Since there is no gasket there is no "part number" other than the silicone. I asked my warranty administrator wife and she thinks it would be coded to the pan... but her service department has not done one under ESP either. They WILL start showing up. I guarantee it. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted February 28, 2021 Share Posted February 28, 2021 I would think the causal would be the upper pan for sure, or as a stretch you could try the block assy. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted March 1, 2021 Share Posted March 1, 2021 For the sake of needing to replace a part, I would go with the upper pan as well. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 29, 2021 Author Share Posted August 29, 2021 Why shouldn't silicone be considered a "failed part" - I see it as being no different than a crank seal or a vacuum pump gasket for example. Especially since Ford has replaced many gaskets with silicone on all of their engines. This shouldn't even be an issue. ESP is just fucked up. Quote Link to comment Share on other sites More sharing options...
lmorris Posted September 7, 2021 Share Posted September 7, 2021 I have always used 6781 for upper oil pans, regardless of warranty coverage. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted September 25, 2021 Author Share Posted September 25, 2021 I think my wife told me you check coverage by using the upper pan basic. It's kinda like ESP wiring repairs, you use the basic part number of the specific harness. Quote Link to comment Share on other sites More sharing options...
