19S54
forddieseldoctor
Is this the f-150 master cylinder recall? If so, don't bother with the bleeder screws.  Bench bleed it 5 or 6 full strokes. Once installed fill it about 1/2 way, and put it under vacuum via the filler cap ( I have an adapter that I built) with a hand held vacuum pump, for a few minutes. Done. Works every time.
Response to this recall by the techs here that had done it is not good. And we recently dropped the BG fluid/additive gig and they took our only good brake flush machine with them(it was provided by them so we could use their products)... :whattodo:
