6.0 AMBULANCE HEAD JOB
DOING MY FIST AMBULANCE HEAD JOB, WILL THE PASSENGER HEAD COME OUT WITHOUT PULLING HEATER BOX?SOMEONE MADE A REAL MESS OF THE WIRING ON THAT SIDE AND IT HAS REAR HEAT AND AIR ADD ON.PULLING THE CAB IS OUT OF THE QUESTION WITH THE LIFT I HAVE. ANY IDEA'S AND SUGGESTIONS? I KNOW U GUYS HAVE BEEN THERE. WE ARE A SMALL DEALER AND DON'T DO ALOT OF THIS KIND OF STUFF.I THOUGHT I MIGHT COULD TAKE THE ROCKERBOX OFF AND DO IT BUT DON'T KNOW THANKS,
Ha good luck, if you have the equipment I think it would be much easier to pull the engine out and do the head. You can hardly get the valve cover off in chassis much less any thing else.
I feel bad for you man, work like that on a minibus or ambulance will make you want to set yourself on fire.
