Steve Mutter Posted March 29, 2022 Share Posted March 29, 2022 We have a truck that came to us with the fuel pressure/temperature sensor leaking. They told us that they have replaced 2 and it keeps leaking. So we put another sensor and pigtail and it started leaking again after about 5 minutes. I have never seen this but I guess there is some kind of restriction in the fuel line, the truck runs and starts good other wise. Has anyone else seen this ? Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted March 29, 2022 Share Posted March 29, 2022 Nope. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted March 30, 2022 Share Posted March 30, 2022 Wouldn't over pressure show in the pid data? Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted April 3, 2022 Author Share Posted April 3, 2022 Well I think it's fixed, the water drain was causing air to enter in the system. Someone replace the end gasket on the drain with two o-rings. We put a new one in and drove it for a long time and found it did not blow the sensor out. Very odd because I have see a lot of frame mounted fuel filters not fully installed and they did not cause this problem. If it come back I will update this. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted April 3, 2022 Share Posted April 3, 2022 Wow. That is special. Time will tell I guess. Quote Link to comment Share on other sites More sharing options...
