OHNO60 Posted March 1, 2007 Share Posted March 1, 2007 WHAT IS THE "RULE OF THUMB" YOU GUYS USE FOR MONITORING THE IPR PID WHILE DRIVING/PERFORMANCE DIAG?I HAD ONE THAT ON WOT OR HEAVY ACCEL CLIMBED TO 78-79%, TRUCK RUNS GREAT GREAT POWER,ETC. Quote Link to comment Share on other sites More sharing options...
snw blue by you Posted March 1, 2007 Share Posted March 1, 2007 Seems pretty typical. If your brave enough to keep it to the wood you can see it go all the way to 85% and be doing 107 mph pulling a grade in a crew cab 350 and feel it run out of fuel. That translated into just over 4000 psi. You can also achieve the same effect at WOT 3400 rpm hold MAN 3 and stand on the brakes and fuel loading the engine to 2500 rpm, should go to 83-85% and around 4000 psi. One thing is for certain if the HPOP is going to fail this is when it will happen. 25 to 80% seems normal but there are lots of variables to IPR duty cycle. I just drive em like my hair's on fire and I'm being chased by Johnny law. Quote Link to comment Share on other sites More sharing options...
