blown99 Posted June 13, 2022 Share Posted June 13, 2022 Working on a 2013 F-250. Truck came in with a locked up lower end, replaced the shortblock, replaced hpfp, put everything back to stock, flashed back to oem ford calibration. I need to get this truck through emissions for the customer. Verified IQA are correct, reset all systems - fuel, exhaust, etc. I have driven it several hundred miles. Runs perfect. Unable to get the fuel system monitor to set (as well as the dpf but this will pass with one monitor not set) If I open the monitor up, it has several test that have completed. One test that has not is pictured in the attachment below. I have searched through ford tech service/dealer connection, pced, wsm, I am not seeing any breakdowns of what each monitor is as far as what is displayed in this pic. ECU ID: $E8 OBDMID: $81 Test ID: $99 Value: 0.000 Min. 0.000 Max: 0.000 Result: Not Complete Can one of you point me in a direction? Won't load my picture - sorry Quote Link to comment Share on other sites More sharing options...
