greg.gustaf Posted November 11, 2022 Share Posted November 11, 2022 I have an 05 6.0L, came in for oil change and sold fuel injection. Sat for two weeks and customer picked up saying it had no power. Suspect the concern always present. Boost test, no boost at all. Tested the turbo and found it was not boosting at all. Replaced the turbo. Has boost and low power. Had p2285 low icp code but it has not returned. Watched the pids for that code and pressure was equal after running. Did pc/ed for hard start and high pressure oil leak test. Heard a small leak under right side valve cover that went away quickly. Suspected stand pipes and plugs, 40k original miles on this engine. Replaced the plug and pipe, re assembled and now it took forever to start. Will now start but only cold and will not idle at all. Suspect the high pressure pump not building pressure but I cant test due to not having the right special tools. Thank you for any help. Quote Link to comment Share on other sites More sharing options...
batmantech Posted November 11, 2022 Share Posted November 11, 2022 Lets start at the beginning, So it ran fine came in for oil change and you stated "sold fuel injection". What is that? Also you stated after replacing the stand pipe "it took forever to start". it should crank long after that repair. Did you drive to bleed the air out of the system? Quote Link to comment Share on other sites More sharing options...
batmantech Posted November 11, 2022 Share Posted November 11, 2022 What is IPR and ICP reading What about the STC fitting on pump? Quote Link to comment Share on other sites More sharing options...
greg.gustaf Posted November 11, 2022 Author Share Posted November 11, 2022 Im sorry for the vague description, the fuel injection was the bg service and did the oil change. I have changed the fuel filters that were garbage. The customer states that it ran fine but i can only assume this does not happen over night. It took days of cranking to get it to start, I think thats due to the oil being put back into the pan and none in the system. I can run it cold, not hot. i have started it cold, revved to 3000 rpm and stayed for 5 mins and it still does not idle. After it will not start at all. The last known icp was 735 approx and the ipr was 25 or so. Quote Link to comment Share on other sites More sharing options...
greg.gustaf Posted November 11, 2022 Author Share Posted November 11, 2022 new known icp is 645 while cranking and it started briefly, ipr 84 percent. then it died and the batteries too. Quote Link to comment Share on other sites More sharing options...
batmantech Posted November 11, 2022 Share Posted November 11, 2022 That IPR is maxed out. I would air pressure check it again. Listen close to both sides. I would bet it has a leak. Possibly STC fitting --snap to connect on high pressure pump. (Your fighting air in this system after a repair it needs to be driven to remove. I have no experience with the BG wallet flushes , but that could have also induced more problems) 1 Quote Link to comment Share on other sites More sharing options...
greg.gustaf Posted November 16, 2022 Author Share Posted November 16, 2022 Thank you, I will do that. I appreciate your help. 2 Quote Link to comment Share on other sites More sharing options...
greg.gustaf Posted November 18, 2022 Author Share Posted November 18, 2022 REMOVED THE IPR AND FOUND THE SCREEN BROKEN, O RING TORN AND THE PIECE OF THE O RING PLUGGING THE VALVE. REPLACED AND THE CONCERN IS GONE. THANK YOU FOR YOUR HELP 2 Quote Link to comment Share on other sites More sharing options...
batmantech Posted November 18, 2022 Share Posted November 18, 2022 Nice Find! Quote Link to comment Share on other sites More sharing options...
