60,000 LB Lift Retired
My faithful companion for the last 25+ years is shot... creeping, leaking and not going all the way up. I have no idea how old it actually is but it's a Weaver in-ground with a sliding front post that had the rear unit replaced 30 years ago with a Rotary. Equipment company tried new seals then it was test twice - the second time each component and the pipes were tested individually. They called it. Supposedly the company is going to install an entirely new lift which is unitized in a casement with a new floor and epoxy paint when it's done. Of course, this is only after the EPA is satisfied with the ground.  So, for now, when I need a lift I'm back out in the main shop with the "general population" and a 15,000 LB Rotary above ground lift.
I'll update on the progress as things progress. Whenever the hell that is!
