p1206 , replaced injector and overlayed harness
have a 2011 f250 97000 miles keeps throwing p1206, will run ok  then get on it hard when taking off and it will kill the whole bank of injectors 1,4,6,7 and have a code for injector 6 continuos memory. cut the key off and restart it will run fine. koer test it will pass even when the whole bank of injectors is shut down. is the pcm a possible cause? I have replaced the injector and overlayed the wiring. relative compression also shows good.
The Isolation Meter detects insulation resistance up to max. 8 GΩ (with auxiliary voltages of 250, 500 and 1000V). In addition, this Isolation Meter offers a measuring function for DC and AC voltages up to max. 950V DC and 700V AC as well as resistors up to max.
  • Like 1
Did you ohm check all injectors on the bank that is missing? PPT P2 check them after driving and its missing.  Easily done at the PCM connector. I had one that only failed the ohm check after driving it.
