ErickBaker Posted April 23, 2007 Share Posted April 23, 2007 Can anyone tell me the part number for a compressor shaft seal? I know there was a TSB our for it but Shop key doesn't give it to me. Our local Ford store says you have to get the whole compressor but I know I have replaced just the seals before. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted April 23, 2007 Share Posted April 23, 2007 Eric do you have the vehicle info? I'll see what I can do to help you out. Quote Link to comment Share on other sites More sharing options...
ErickBaker Posted April 23, 2007 Author Share Posted April 23, 2007 Vin 5LMPU28L7WLJ26675 1998 Lincoln Navigator 5.4L EATC with Auxilary Air. Thanks. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted April 23, 2007 Share Posted April 23, 2007 Eric as far as I can tell, you have been given the correct info about the shaft seal not being avail. but I could be wrong I'm going to check a little deeper and find out for sure. It's getting late for me. ITS TIME FOR BEER /forums/images/%%GRAEMLIN_URL%%/cheers.gif I'll let you know for sure tomorrow. Quote Link to comment Share on other sites More sharing options...
STROKERTEC45 Posted April 24, 2007 Share Posted April 24, 2007 I also remembered seeing a tsb for a/c shaft seals so I went for a search and could only find this tsb 06-4-9. Be carefull I dont think it applys to your year /forums/images/%%GRAEMLIN_URL%%/hammer2.gif /forums/images/%%GRAEMLIN_URL%%/banghead.gif Some 2002-2006 vehicles equipped with an FS-10 A/C compressor may experience a non operational A/C compressor due to a low freon level caused by a leaking shaft seal. ACTION: Replace the A/C compressor shaft seal following the Service Procedure. SERVICE PROCEDURE If the shaft seal on the front of the A/C compressor is leaking, replace the shaft seal (F1VY-19D665-A) and not the compressor assembly. Replacing the shaft seal should correct the leaking condition. When replacing the seal, follow the procedure outlined in Workshop Manual, Section 412-03. PART NUMBER PART NAME F1VY-19D665-A A/C Compressor Seal Kit Quote Link to comment Share on other sites More sharing options...
