ErickBaker Posted May 22, 2007 Share Posted May 22, 2007 I was wondering if any of you parts professionals could help me with a little problem. I'm trying to replace the differential in my truck but my two local Ford dealers are contradicting each other. I remember when I worked for Ford they told me there was a complete kit I could buy to rebuild the differential. My truck info is... 2002 Ford Ranger Edge 2WD 1ftyr44u92ta18690 8.8 inch 3.73 Locking diff One dealership is trying to sell me this part number... 5l32-4209-c The other tells me I need to buy everything individual and the first part number doesn't even go to my truck. I really want to get the right stuff the first time so I don't keep a lift tied up at work. Thanks in advance guys. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted May 23, 2007 Share Posted May 23, 2007 Hey Eric I just looked it up and came up with a different # 5L5Z.4209.A it consists of ring gear and pinion set,locknut lube,shims and spacer. If they want to look it up again the axle code is V367B, parts list #3. Hope this helps!!! /forums/images/%%GRAEMLIN_URL%%/cheers.gif Quote Link to comment Share on other sites More sharing options...
ErickBaker Posted May 24, 2007 Author Share Posted May 24, 2007 I appreciate your help. I believe what they sent me was for the IRS rear ends in the Explorers. The pinion was about an inch longer. Quote Link to comment Share on other sites More sharing options...
