7.3 injector question
has anyone ever tried the number 8 only injector in another cylinder.if so did it run ok any problems? parts has it but not the regular one like it lists for cylinders 1 through 7 2000 7.3 liter f250
From my understanding, we can use a standard fuel injector in #8 with no ill effects but using a long lead injector in other cylinders would overfuel those cylinders....
The long lead injector is a split shot design (as are all 7.3 injectors since - IIRC - the late 90s) and delivers more fuel in the "pilot" injection than a standard injector....
You may be right, but my understanding is a bit different. The split shot is delayed, same fuel delivered, but delayed a bit to allow oil pressure to return after being slightly depleted by #6 firing just before it. Either way, I wouldnt recomend using it elsewhere..
