Brad Clayton Posted June 16, 2007 Share Posted June 16, 2007 We had our first 6.4l come in with a blown out radiator. It's an F-450 with a huge fifth wheel camper. I think they drove it 'til it wouldn't go anymore 'cause she smells burnt. Anyway the radiators are D99, should be interesting to see how the customers response is to this. Our GM asked the tech about swapping a rad. from a stock unit, his response was not nice. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted June 16, 2007 Share Posted June 16, 2007 Which part # have you ordered? The 8005 Radiator is just the Radiator. The 8009 is that plus the 8124 mounts, the Detroit national pdc shows 9 in stock should be 2 days. You might want to check it out. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted June 16, 2007 Author Share Posted June 16, 2007 I'm not a 100% sure but I will check into it Monday. Thanks for the heads up. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted June 18, 2007 Author Share Posted June 18, 2007 I checked with parts this morning and had them look up an 8009 and it will be here tomorrow. This info was extremely helpful thanks again. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 7, 2007 Share Posted August 7, 2007 Quote: SSM 0107 - 2008 F-SUPERDUTY - 6.4L ENGINE - MAY EXHIBIT COOLANT LEAKS LOCATED AT THE RADIATOR SIDE TANK CRIMPING AREA. SOME 2008 SUPER-DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE MAY EXHIBIT COOLANT LEAKS AT THE RADIATOR SIDE TANK CRIMPING AREA. ALL SERVICE PARTS WITH A BUILD DATE OF 7/9/2007 OR LATER ARE CERTIFIED STOCK. BEFORE INSTALLING SERVICE PARTS VISUALLY INSPECT TO ENSURE THAT END TANK CRIMP TABS ARE COMPLETELY CLOSED AND NO CRACKS ARE PRESENT AT THE TRANS COOLER LINE FITTINGS OR INLET/OUTLET PORTS. BUILD DATES ARE LOCATED ON A YELLOW OR WHITE LABEL LOCATED ON THE TOP RADIATOR CROSS RAIL. AFTER THE RADIATOR IS REMOVED FROM IT'S PACKAGING INSPECT TO VERIFY THERE IS NO DAMAGE PRESENT THAT MAY RESULT IN A LEAK OR REPEAT REPAIR. Quote Link to comment Share on other sites More sharing options...
DieselD Posted August 7, 2007 Share Posted August 7, 2007 Ive done 2 of those now..... Quote Link to comment Share on other sites More sharing options...
