Running engine with cab off?
I was thinking it would be nice to start the engine for 30secs or so to check for exhaust/oil/fuel leaks after a repair and before you bolt it all back together just to find out it all has to come back apart again...
Anyone tried it?
  • 4 weeks later...
Had a f450 body off a couple weeks ago and tech line wanted me to remove rear fuel plugs and enrgize and deenergize injectors and it was not possible that I could see. Turned out to be h-p fuel pump scored and at wot pressure dropped from 26,000 psi to 1,800 psi. I am so thick into diesels I tatooed psd to my arm with Taz on it. Just started to naccess site looks good.
