SVB 2007-29N
Alex Bruene
Incase nobody has seen this message, it deals with what do do if a 6.4 equipped vehicle is filled with gasoline. It says that if the engine has been run, you have to replace ALL the high pressure fuel components, such as lines, the high pressure fuel pump, all the injectors... yada yada yada... I'm not looking forward to the day I have to hand in that estimate!
