escort coolant loss
Steve Mutter
just got a 1996 1.9L for cheap,but this thing is losing coolant, have to put about 1.5L everyother day,it looks like the oil level is going up but I am not 100%,where do these things leak from,in the cylinder head? I don't see anything leaking on the ground,
HAS IT BEEN OVERHEATED?HAD SEVERAL YEARS AGO LEAK COOLANT BETWEEN THE VALVES ,SMALL CRACKS CHECK YOUR HEAD REAL CLOSE ALSO SEEN MORE HEAD GASKETS THAN ANYTHING. PUT IN DYE IN COOLANT ,YANK VALVE COVER AND PLUGS IT MAY SHOW UP WITH THAT MUCH LEAVING. A BOROSCOPE MIGHT ALSO HELP YOU .HOPE THIS HELPS
Head gasket and/or cracked cyl. head. Also look out for the valve seat dropping out of the head, it was a problem with some of the 1.9's. I've not seen much in the way of block problems, but you are adding a bunch of coolant so nothing is out of the question here.
Thanks for the info guys,I am going to pull the head when I find some time(working on the branch tubes on an e-box) what is funny is it does not run bad,even at first start
up,I will let you know what I find, thank again
