Keith Browning Posted May 17, 2010 Share Posted May 17, 2010 This is a list of hard to find and oddball parts that is good to have on hand. If you have numbers you would like to add to this list or see any part of this list that is incorrect or requires updating because the part number has been changed please PM me with the information and I will add it to the list. Part # Motorcraft # Part Description 4C4Z-9365-BA FD-1065 7.3L fuel screens in the tank DTRM pickup assembly 2C3Z-9G804-AB 7.3 DIT oil supply fitting kit @ HPOP F4TZ-9N693-A 7.3 DIT fitting & plug o-ring @ cylinder heads F81Z-9C387-BA 7.3 DIT Fuel supply line o-ring service kit. 6E7Z-12A690-DA 6.0L IPR Valve/VGT Actuator Connector Pigtail Kit 3C3Z-6C683-AB Oil Cooler reservoir to HPOP screen 6.0L W302725 Green o-ring; Breather to left valve cover 6.0L W300049 6mm valve cover component attachment Nuts 6.0L & 6.4L 1C3Z-9g486-AA Turbocharger Turbine Housing Bolts #4 7.3L 3C3Z-9H529-A 6.0L IPR Screen Kit 4C3Z-9B246-F 1 piece HPOP fitting 6.0L (replaces STC fitting) 6E7Z-9A332-B Stand pipe kit w/o-rings 6.0L & 4.5L 3C3Z-9K024-AA HPO Rail Plug and Seal, Left side, ICP hole 4.5L 3C3Z-9433-AA Intake manifold & EGR cooler gasket set 6.0L 3C3Z-9T517-AG Fuel Pressure Regulator w/blue spring 6.0L 6E7Z-9C165-B Fuel Pressure Regulator w/blue spring SPRING AND SEALS ONLY 4.5L/6.0L 3C3Z-6C885-A VGT unison ring 6.0L 3C3Z-9T514-DA VGT Install Kit 6.0L (bolts, o-rings, gasket) W302193 6.0L Rocker arm plastic clip 3C3Z-8287-CA 6.0L EGR Cooler Clamp 3C3Z-6026-DA 6.4L Fuel Cooler Coolant Air Bleed Plug 8C3Z-9A214-B 6.4L DCFM Water Drain Valve Kit EC3Z-9B246-A 6.7L Complete High Pressure Fuel System Replacement Kit BC3Z-6N958-A 6.7L Fuel Injector Sound Insulator Push Pins BC3Z-9B246-A 6.7L Fuel return line repair fitting at engine fuel filter Link to comment Share on other sites More sharing options...
